Kubota tractor front loader hydraulic issues
   / Kubota tractor front loader hydraulic issues #1
rcbor187
Cali
Kubota RTV 900
So I came back last monday to find the tractor in need of repair or diagnosis. When switching from forks to bucket the two hydraulic cylindars seem to be not in sync with each other. It almost seems like something is bent. I do notice that when Im standing and looking at the front , comparing the two hydraulic shafts, one is extended farther out then the other.
I spoke to the dealer and they said I could try draining the entire hydraulic system, in hopes to sync the two front cylindars.
This seems like an awful lot of work.
Was hoping someone with more experience can chime in and let me know what they think.
Thanks
the issue is with the quick connect feature.
I have reposted this in kubota tractor area.
   / Kubota tractor front loader hydraulic issues #4
Some dealers don't have any common sense. Draining hyd oil won't get bucket cylinders into synchronization but gently placing quick tach bracket(if applicable) against something solid & putting a little pressure on the cyl that is most extended one can easily even the rod length of both cylinders.
   / Kubota tractor front loader hydraulic issues #5
In the same vein if you get square with an immovable object with your quick attach then curl it down so that the side with cylinder more extended is contacting it solidly then curl it more till the other side makes contact you should be squared up again.
We are saying the same thing just in different ways.:thumbsup:
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
