Kubota won't start & puffs blue smoke
   / Kubota won't start & puffs blue smoke
Problem solved :D
I had the tractor serviced today and the mechanic solved the problem.
It was indeed a sticky rack and I now even know how it works along with the govenor system of springs and fly weights.
There is however a bit of a down side in that the springs are old and stretched a bit which is not allowing me max revs. He was also not sure if he could get new ones, being a grey market tractor.
So does anybody know where I might get govenor springs (there are 3 of them) for a Kubota D1102 engine.
Cheers
Rohan
   / Kubota won't start & puffs blue smoke #43
Wow- so all this time it was a fuel issue; sounds like David_Kb7uns nailed it!
This has been a very educational thread, from start to --almost finished? rhamer, thanks very much for all your updates. I'm sure we've all learned something here.
(I hope I never have to take my injector pump apart... going back to my old 504D wagon, I often described the pump as "being built like a Swiss watch"! If you'd like to hear an interesting story, research Rudolph Diesel and a guy/company named Bosch around the turn of the century....)
If you have no luck with your springs as replacement parts, you might be able to find a spring specialist-- don't know if there are even such folks around anymore, but it used to be that there were shops which could fabricate small coil springs to order. WBB in NH
   / Kubota won't start & puffs blue smoke #44
back in post 6 I was betting on sticky rack.. glad it turned out to not need a big deal of work to correct.
thanks for posting back
soundguy
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
