L 3240 HST
   / L 3240 HST #21
I've been using a 6' Deere Brush Hog on my L2900 for 7 years and never felt the 29 HP was inadequate. I've cleared areas where the vegetation was at deck level. In places like that, running slow is prudent because there are hidden hazards.
With my new L3240, I cleared a firing range on the back of our place that has not been cut in many years. I felt the power to be more than adequate, but I did need to cut in both directions, up and down to be sure that all the vegitation and small trees were cut.
   / L 3240 HST #22
One of my co-workers has a 3240 GST and pulls a 6' cutter no problem. I just picked up my 3240 over the weekend and will be looking for a 6' cutter as well. I was on the fence but I guess I can always cut less than 6' wide if necessary. I don't plan on letting the grass get very high between cuttings anyway.
   / L 3240 HST #23
I have a 5ft cutter on my L3240 GST and have not bogged it down BUT I can see a 6ft might.. Also one thing to remember is that a 6ft will be wider than the tractor sits so for me thats a big disadvantage when cutting around trees. If they tractor goes in between them then the cutter will follow..:thumbsup: I have AG tires..
AndyG
   / L 3240 HST #24
"So far, very pleased, but still learning how to use the machine. Anybody with operating experience with the HST speed control is welcome to comment."
Are you referring to the Cruise Control or the foot pedal?
   / L 3240 HST #25
I have been able to mow 4 foot field grass in 3rd or 4th gear at PTO speed with my L3240GST and a 5 foot hog. I think it would run a 6 footer at that speed in 2 to 3 foot high grass. The 5 foot deck is very maneuverable, making mowing between trees around field edges easy. The shortie also keeps the CG a little closer to the rear axle for good balance.
-Jim
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2002 New Holland TN75S 4X4 Loader Tractor (A51243)
2002 New Holland...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
