L-39 Hydraulic Pumps, Number and Flow
   / L-39 Hydraulic Pumps, Number and Flow #1
catvet
Hyde Park, Vermont
Kubota L-39
I'm probably crazy (my wife would say get rid of the Probably) but I seem to remember that the L-39 has multiple hydraulic pumps (three if my memory serves correctly). Some one at the dealership said that wasn't the case.
Any info appreciated. If there are multiple pumps anyone know the flows?
   / L-39 Hydraulic Pumps, Number and Flow #2
According to the literature I have, the L39 has 3 pumps, one for the backhoe and implements @ 11 gpm, one for the power steering @ 6.2 gpm and one for the boom swing @ 6.2 gpm. This info is also available on the Kubota website. Your dealer's employees need additional education/training.
Thanks Mad,
That was the information I was looking for. For some reason I couldn't find that on Kubota's website.
   / L-39 Hydraulic Pumps, Number and Flow #4
Unlike the L48, the L39's pumps are encased inside of the transmission housing area. The L48 has a pump that is in front under the radiator and it is driven by the crankshaft. The L39's pump capacity is almost the same as the L48.
   / L-39 Hydraulic Pumps, Number and Flow #5
I spoke with a dealer at the end of 2006 about the L39 and my potential hydraulic uses. I'm not an expert by any means on the L39 hydraulics nor even the possible configurations; however, it was clear that the dealer knew less than me. So, I'm going to attempt to breathe life back into this thread in hopes of getting some more details regarding the L39 hydraulics.
Let's remove the 6.2 gpm power-steering pump from the equation, and we're left with (quoting the L39 brochure) the 6.2 gpm for the "backhoe boom swing" and the 11 gpm for the "loader/backhoe". Can anyone elaborate on these a bit more?
Is the 11 gpm pump used for the front (FEL) remote hydraulics as well as the rear (backhoe) remote hydraulics? If so, do the remotes "steal" flow from the rest of the FEL/Backhoe functionality?
Is the 11 gpm pump tapped into for the TNT?
Is the 6.2 gpm truly only for the backhoe boom swing?
I want to mount a hydraulic PHD on the backhoe dipper-stick, and want to ensure a dedicated 11 gpm (10+) gets to it in order for it to be more effective. Is this a do-able configuration?
These may be ridiculous sounding questions, but I'm learning.
   / L-39 Hydraulic Pumps, Number and Flow #6
Yes. However, remember that valves are in series. When only one is activated it has the full use of any flow in the circuit. If more than one is activated simultaneously the first one in the series circuit will have the advantage of the full flow. Valves after that one will get some flow depending on the design of the first valve. No valve "steals" from another.
Yhe valves for the remotesthat are used for the TNT are in the same 11 gpm series circuit as the loader.
I believe so since it is it's own seperate pump.
Sure. It all depends on how and where you hook up the PHD and that you have no other hydraulic valves activated in that circuit when the PHD is in operation.
   / L-39 Hydraulic Pumps, Number and Flow #7
Thanks. I think I am following you. I just don't want my PHD to lose it's umph while pushing it into the ground.
   / L-39 Hydraulic Pumps, Number and Flow #8
Kubota builds a hydraulic boom kit for adding hydraulics to the hoe. Kubota built it to run a 300lb hammer off the hoe. I've used it to add hydraulic drive augers before in place of the bucket and it works fine. The kit is #BTB404 and in the book retails at 1,545. A good auger is worth the most here.
   / L-39 Hydraulic Pumps, Number and Flow #9
That is exactly what I had in mind.
The BTB404 Remote Valve Kit includes a right foot operated valve, hoses, pipes, and brackets ... according to the information that I have.
   / L-39 Hydraulic Pumps, Number and Flow #10
To have the right auger drive head as there are several types and the right diameter auger and your all set! I normally for NY use a auger that is for frozen ground and or blacktop do to the variations in conditions.
Two Post Car Lift (A50120)
Two Post Car Lift...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
John Deere 4050 (A53314)
John Deere 4050...
John Deere 7130 (A53314)
John Deere 7130...
