L118 Rear Transmission failed
/ L118 Rear Transmission failed #1
JoeCDARPO
Halfmoon, NY
L118 Lawn tractor
John Deere L118 needs sealed rear transmission replacement ($800) after only 215 hours of operation over 9 years.
Should I repair or buy new mower? This seems like an early grave for an otherwise good-condition machine. There must be a better option -- like a recall from John Deere to replace the transmission FREE.
Is 215 hours reasonable time to expect this trouble?
/ L118 Rear Transmission failed #2
The life expectancy various by use of the mower more than quality of the tranny. The problem with most of the lower end mowers is the hydrostat tranny isn't made to pull much more than the weight of the mower. So any towing of lawn carts with dirt in them, lawn rollers, or aerators, causes the oil to overheat and loss of lubrication, leading to pump damage. Most of the tranny's are repairable if you want to spend the time to do it.
/ L118 Rear Transmission failed #3
That's a cost of about $100 a year for a lawn mower. You can put in a new tranny, or compare the cost of buying a replacement lawn tractor.
Doubt Deere has any plan to replace after 9 years. After one year, more likely to happen.
/ L118 Rear Transmission failed #4
Rebuild the transmission yourself.. thousands have. Here is your guide.
http://www.tractorbynet.com/forums/...-k46-repair-guide-pictures.html?highlight=K46
4ft Mini Skid Quick Attach Rotary Cutter (A61306)
4ft Mini Skid...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2018 Ford F-350 (A55973)
2018 Ford F-350...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
