L2500DT alternator upgrade
   / L2500DT alternator upgrade #1
WillyC93
Post Falls, Idaho
Kubota L-2500DT (2000)
Has anyone installed a larger alternator on a Kubota L2500? If so, what did you use? If not, is there a sourse for the physical dimensions and specifications of small/high output alternators such as Denso, Mitsubishi, etc? I am installing additional lights, maybe a cab, and want to increase from the 30 amps available to 45 amps to 60 amps. Thanks, willyC93
   / L2500DT alternator upgrade #2
Sorry I cant help with your question but I have a question for you. How did you find what your alternator output was ? I have a L3010DT and have looked in my manuals and on the net for specs and other places but couldn't find the answer. Thanks.
gg
   / L2500DT alternator upgrade #3
Alternators are pretty standard--there's only a few ways they mount (single foot, double foot, etc). West Marine carries a bunch for people who want to boost the charging capacity on their boats. Here's an article that might be helpful: The West Advisor: Alternators
West carries a bunch of HO alternators, but they're all Balmar and pretty spendy (like most things nautical:D). Another alternative would be to change the pulley size to make your alternator spin faster, since their output is proportional to the shaft RPM.
   / L2500DT alternator upgrade #4
If you decide that additional lighting is really your goal, consider using LED lights that use a fraction of the current used by other technologies. LED is higher cost compared to halogen, etc but likely lower cost when compared to halogen + replacement alternator.
Mike
   / L2500DT alternator upgrade #5
I would also suggest LED lighting.
I would also see if there is an alternator shop in your area. They may be able to rebuild your current one with a higher output. Or at least be able to advise on a source for a higher output unit.
   / L2500DT alternator upgrade #6
The guy who suggested a marine alternator hasn't looked under the hood of a 2500. What you need is a same mechanical size and mounting with twice the output power. So do I by the way. If you find one let me know. I need one and I'm not even adding lights.
   / L2500DT alternator upgrade #7
I am trying a solid state regulator. It exactly replaces the mechanical one and is not subject to vibration and corrosion. It's a cheap improvement on the L2550 and others.
   / L2500DT alternator upgrade #8
Do you know the manufacture and p/n of your current alternator?
Denso痴 website has listings for Kubota products, but it doesn稚 provide physical size info. It does list which P/N痴 are above 40 amps. Perhaps if you contacted them (or the appropriate manufacturer) they would provide some help.
Find My DENSO Part (Heavy Duty Product Search)
   / L2500DT alternator upgrade #9
I took my alt. to a shop a few years back to have it rebuilt, the repairman asked me why I wanted to rebuild it when I could get a new one for around 85.00. He ordered it and it was a carbon copy of the old in every form. It was designated to gon on a 4cyl toyota car, it's been singing along for 5 yrs now with the same output.
2006 TerraGator 8104 (A56438)
2006 TerraGator...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
