OP
8226hamer
- Joined
- Apr 4, 2003
- Messages
- 179
- Location
- Indiana
- Tractor
- Started with a B-20 Kubota, then B2910, now L2800
I'm still waiting for a reply Kubota. Here your chance to clean up some "dirty laundry".8226hamer said:If Mr. Gertner or anyother Kubota represenitive is following this thread and if they do not care to answer this question I have about the PTO system that the earlier L2800-3400 tractors incorporate. Do you feel using it to run a roto tiller is the wrong type of application for this system, and with the changes that Kubota has made since the early tractors is the new system an improved, better system, or should an independent system that such as the non economy tractors use better suited. I know what the Northern Division of Kubota Corp. answer to this question was. What would be your solution to the fact that the system in my L2800 has faild twice with the low amount of time that it has been used and also thae fact that another TBN member has had his system fail also.
Repairing while still under warranty for three years, Kubota should be obligated to do so, but what kind of outlook would anybody have that was in my situation, which is having to have the system repaired with 30 hours of PTO use, when the three years have expired and you then yourself is looking at paying the cost for this repair.
Fixing my tractor for three years is not an answer to the problem wheter it's an isolated case or not. You would think Kubota would want to take a look at my tractor and see if there are other problems with it rather than my claims that it an inferior system. The tractor is here for you to take a look at if you like. I will need a replacement tractor for it the time it takes for you to remedy this problem. If you can do this this then I would feel Kubota has did the right thing in this situation, but fixing it for three years under warranty is not. I'll be waiting for your answer , wheteher on this board or by PM.
