OP
8226hamer
- Joined
- Apr 4, 2003
- Messages
- 179
- Location
- Indiana
- Tractor
- Started with a B-20 Kubota, then B2910, now L2800
I was looking in the warranty guide that came with my tractor and I still can't understand why that this repair that has been done twice to this tractor and was covered under the bacic warranty which is for a period of 24 month or 1500 hour would not be still be covered under the powertrain warranty. The warranty guide states what is covered in powertrain warranty
Driveline: 4 wheel drive front axle assembly, and all gears, seals, bearings, etc.,m contained within, clutch housing ( except clutch disc), transmission case, and rear axle housing and everything contained within, and pumps and valves associated with driveline operation.
The next section is Service Parts Warranty
Service parts are warranted for 90 days from date of purchase. However, if the part is installed on a unit which has more than 90 days remaining on the original warranty, the part is warranted for that remaining time. If the part was installed by an authorized Kubota dealer, the labor to replace that part is also included. Replacement batteries have warranty periods ranging from 18 months to 36 months, on a pro-rated basis
The locking cams are contained within the transmission. I don't consider them clutch disc. I associate clutch discs with a manual gear driven transmission and they are prone to wear and I can see why they would not be covered. Pto clutch cams have no lining to wear and should not be prone to wear, at least on a tractor with 221 hours and a little over 25 hours of PTO use. I know that warranty information can be interupted different ways, by the way I see it, these locking cams should be covered for 36 months or 3000 hours. The L2800's that have a serial number later than 57745 were fitted with a new designed locking cam. The first design were no good as my tractor came out with the old style cams and did not last 40 hours of use. You would think that with Kubota knowing these tractors had problems would be a little generous it taking care of this problem, especialy since the new design didn't last me a whole lot longer than the first ones.
Another question. Their service parts warranty states a 90 day warranty for parts and labor if they were installed by an authorized dealer. Should my new cams be covered for 90 days? The way I see it they should, and this would give me a little more safe time. June, 4 my basic warranty expires.
When I first ask the service manager about this repair being covered under the powertrain warranty, I thought he was joking when he said it might be, but I may have to get a lawyer to prove it, I guess he was serious. The more I think about it, it may be good advise.
