L2800 PTO and service problem.
   / L2800 PTO and service problem. #11
Sounds like your dealer is jerking you around. I'd go down there and tell them I'm not leaving until I know when I am going to get it and what is going on. I'd also inform them if I don't have it this week all further conversations will be with my attorney. I've always said that the dealer is more important than the brand.
   / L2800 PTO and service problem. #12
My 3PH was jerky on a new L3400HST. The dealer looked at it, called Kubota and had a new valve in 3 days. No charge. It works very well.
   / L2800 PTO and service problem. #13
I would try to contact your Kubota area rep directly and tell them of your dissatisfaction with your tractor. You should be able to get a phone number from Kubota Corp. I have a west coast number but that will not do you much good. I bet you get parts real quick. I was about ready to look at green tractors or a Grand L before I finally got my 3 pt. valve. Good luck, Brian
   / L2800 PTO and service problem. #14
I sure hope this just a rotten dealer issue and not Kubota in general. We just bought a new L2800 man trans.
Hope your problem is resolved soon.
BNW
Southampton County, VA
   / L2800 PTO and service problem. #15
welcome to the growing list of 2800s on here.mine also is a manual and other than the lift deal which my dealer fixed, it has been superb.my wife thinks i like it better than her,course the 2800 always does what i ask it to with no backtalk.to bad i didn't meet the kubota many years ago.
just kidding,about wife...lol
I got a call Thursday from my dealer saying my tractor was ready to be picked up. I went up Friday morning and picked it up. I sat down and talked with the service manager. My first question was what caused the PTO to go out. He said that the cable that engages the PTO was out of adjustment and that the two cams that engage the PTO was not engaging all the way and that they were both rounded off. These cams are engaged by a spring that puts tension on one of the cam plates.
My nexted question was why did it take 5 weeks to repair? He said that the spring that engages the PTO that they ordered along with the two new cam plates was the hold up. It took that long for them to receive it.
From what I seen this design is a poor set up. The PTO is locking into and running the PTO shaft by two cams that look to be about 1/8"X1/8" and locked into place by a spring. That may be OK for running a bush hog or a finish mower, but for using a tiller that has alot more resistance, I just don't see how it can possibly hold up. I guess time will tell. I have about a half acre lot that I have to till up Monday. I hope that the cable is adjusted correct now and stays that way. I wonder what will happen if the cable does stretch over time and gets out of adjustment is this going to happen again? It seems to me that there is alot riding on this cable being in correct adjustment.
I did get a call from Kubota, and was left a message regarding my problems with this tractor but was not left a contact number and have not hear from them since. I'm going to hope for the best with this tractor and give it another chance. I have had three previous Kubotas and they preformed flawlessly, but in my line of work 5 weeks of downtime can put me out of business. If it does happen again I will have to make a change that I thought I would never be making.
   / L2800 PTO and service problem. #17
There is a post, on another board, about an L3400 with the same problem. It also had the failure while tilling. It had the same cause, the cable. I am concerned about how this clutch will handle my snow blower. Please let us know how the tiller works Monday and if you have more problems.
   / L2800 PTO and service problem. #18
Just curious if your tilling ended up killing the PTO again? Or did the replacement parts stand up?
Any updates?
   / L2800 PTO and service problem. #19
I'd guess no news is good news.
   / L2800 PTO and service problem. #20
Kubota just released a service bulliten on the HST versions of the L2800 and L3400 if you are having a noise in the pto log on to our web site http://www.lansdowne-moody.com/customercare/warranty.htm and view it there. It is way to big to try to post here. Hopefully one of the mods will let this slip as we are not susposed to put links to our websites on the board. It should be there tommorrow sometime as I emailed the service bulliten to him this evening.
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
207278 (A52708)
207278 (A52708)
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
1453 (A57192)
1453 (A57192)
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
