Elliott Wave
Bronze Member
I just started taking a look at my level after reading this. At times, I would get good readings (level groud, fluid visible and below max. amount). However, after reading this and looking at it lately, it seems to be above the max level. I took small amounts out the past couple of weeks, but no difference.
When I start the Tractor up (loader and backhoe down) and let it idle I can see the fluid is right in the middle of the sight glass. Would this be an accurate reading?
When I shut it down lately, it appears above the max. level. I wonder if it is due to an air bubble. Although it the past, when it looked low a few days would go by and it would rise (that seemed more like an air bubble).
My L3400 hst is 3 years old and has 186 hours. I will be changing the transmission and hydraulic filters shortly. Does anyone no how much Super UDT I should buy assuming I will be losing fluid as I attempt to change the filters?
