L3400 coolant change
   / L3400 coolant change #21
Me too, I'm up for my 200 hour change soon and I bet that anti-freeze has been in there since my tractor was built, pretty sure, in 2005. Too bad I bought it new in Dec. 2006. Won't do that again.
My tractor came from the dealer with the yellow long-life (5 year) antifreeze. It's the same age as yours. I figure to service the cooling system next spring.
   / L3400 coolant change #22
I asked about changing my coolant last year, and finally decided to do it, thought I'd share my experience.
After removing the overflow reservoir, and dumping the coolant out of it, I noticed some tan precipitate on the bottom of it. It washed out easy enough but, I decided to buy demineralized water and flush the entire system. I ended up flushing it three times. I was originally thinking I would just drain it and add the new coolant since the Tractor only has 200 hours and is just over 3 years. I chose not to take off any hoses and just use the drain at the bottom of the radiator. As a result, only 4 of the approximate 6 plus quarts of coolant came out each time I drained it.
As noted in the earlier posts, when I filled it up with the pre mix coolant, it was diluted by the 2 plus quarts of demineralized water that was left over from flushing. I ended up having to drain about 5 cups (done over 3 intervals) of coolant and add full strength coolant to get it to the proper freeze / boil over protection level.
Zero Turn Mower (A59228)
Zero Turn Mower...
TANK MANIFOLD (A58214)
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
43055 (A55851)
43055 (A55851)
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A60429)
2014 GENIE...
