L3830HST PTO RPM display - usefull?
   / L3830HST PTO RPM display - usefull? #1
demoman357
Southwestern Oregon
Bobcat CT335, Case 480C
Does anyone really use the display for setting the PTO rpm on a "grand" series? Should one use it?
   / L3830HST PTO RPM display - usefull? #3
I use it since I get the best cut from my flail mower at the rated rpm. It not a finish cut mower but acceptable if I run it at speed, fewer straggler stalks. This is when cutting grass, in light brush it is not as critical.
The same seems to apply when using the Bush Hog (which I rarely do since getting the flail).
Vernon
   / L3830HST PTO RPM display - usefull? #4
if nothing else, you can make sure you don't overspeed whatever you are running.
   / L3830HST PTO RPM display - usefull? #5
I use it quite a bit. I find standard prill fertilizer spreads just right @ 325 rpm.
   / L3830HST PTO RPM display - usefull? #6
I have a L3130 HST and use the PTO RPM reading all the time when using my rear brush mower. It is designed to operate at 540 PTO RPM, and I set my throttle accordingly.
Also, with the digital reading, you can tell how much the mower shows down when encountering high, thick grass for example.
Gary M
Central New Jersey
   / L3830HST PTO RPM display - usefull? #7
Ditto what everone else has said-
I like to set me fertilizer spreader and bush hog to 540RPM so they run at optimum speed.
It also shows you how much you are bogging down when you bush hog up a hill. I ease up on the HST pedal up hill to let the RPM rise back closer to 540. -Mike
   / L3830HST PTO RPM display - usefull? #8
Ditto - Ditto :D
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2018 Mitsubishi Eclipse Cross SUV (A50860)
2018 Mitsubishi...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A48081)
2015 Ford F-550...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
