L3901 vs L4701
   / L3901 vs L4701
I have a L3800 and I run a heavy 5' rotary cutter. It would handle a 6' medium duty without a problem.
If most of your tasks are mowing, and just general work, the L3901 is perfectly fine. If you're planning to do anything with round bales, you need to jump up to the L4701.
I asked the dealer about rear remotes for the L4701. They said they can add rear remotes with valves and linkages for $1500. I assuming thats for one rear remote? And whats the linkage part of that?
   / L3901 vs L4701 #72
Each remote comes as two kits. The lever kit which includes the linkage, control handle and hardware for a specific tractor and a separate valve slice of choice, self centering, with detented float, etc. several models of tractors would use the same valve slice choices.
   / L3901 vs L4701
^^^ Thanks for that.
I was playing around with the Kubota tractor builder and that must be for 3 valves. The price for 3 valves and levers on the builder is like $1700 or so depending which valves you choose.
The dealer didnt mention which ones theyd put on so Ill try to get some clarification from them. I wasnt going to pay $1500 for 1 valve. But for 3 then heck yea. I feel like youd want at least 3.
2023 John Deere 333G Track Loader (A53485)
2023 John Deere...
2003 FREIGHTLINER BUISNESS CLASS M2 SPREADER TRK (A57192)
2003 FREIGHTLINER...
2013 Genie GTH1056 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2013 Genie GTH1056...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A57192)
UNUSED LANDHERO...
Emerson 18' Homemade Trailer (A56469)
Emerson 18'...
