L4240 4wd binding on pavement
   / L4240 4wd binding on pavement #21
I do the same to engage or disengage 4wd or the diff lock. Although disengaging 4wd or the diff lock when wheels are slipping isn't typically a scenario people worry about. :p Problems only show up when one gear is moving at a noticeably different speed. Actually engaging on the fly can be easier to on the operator & the gears as things often just take a nudge to line up & they get that from things already rotating at about the same speed.
Normally engaging the 4wd while moving is easier it's still a good idea to depress the clutch. Depressing the clutch gives a way to dissipate any shock that might accrue during the engagement process.
Learned this the hard way with an old two speed rear end truck.
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
1996 FORD F SERIES DUMP TRUCK (A60430)
1996 FORD F SERIES...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
