Hi,
Please see below for two pictures of the bottom of my L4240 with an LA854 loader with a Third Function Valve. Coming from the main hydraulic fluid drain plug location is a hose leading back to either the third function valve solenoid or the loader. There was an official looking heavy metal orange cover bolted over this to protect the hose fitting that I have removed. I should also mention I have two rear remotes.
I find no mention of this hose or cover in the L4240 owner's manual or the LA854/Third Function Valve installation manual. Does anyone else have this?
Also, when there is such a hose, what's the best way to drain the hydraulic fluid? Anything I can think of will have the draining fluid coming out sideways rather than down. Some predictability as to where the 11.4 gallons of draining fluid is going to go when when I take it apart would be great.
Thanks.
Thanks.
