L6060 ROPS spare bolts (the ones you remove to fold them)?
Status
Not open for further replies.
   / L6060 ROPS spare bolts (the ones you remove to fold them)? #11
So when you are ready to switch back to the factory bolt just run a tap thru the weld nut. How buggered can it get???? It's not like the ROPS is beating back and forth. The main bolt holds it. it's just a bolt/pin dancing around. And if it is a close fit it won't even dance. Just my 2 cents.
gg
   / L6060 ROPS spare bolts (the ones you remove to fold them)? #12
I recommend getting a grade 8 pin slightly smaller than the bolt hole, and wrapping a few turns of black tape around it. This way it won't rattle and it won't damage the threads.
If the black tape gets worn out, simply re-wrap it.
I've done this on other machines before. Works great.
gg
Exactly. The nut is not centering the ROPS bolts...the unthreaded portion of the bolt and the holes in the ROPS bars do that. The nut really on provides clamping force to keep the bolt from rattling. The bolt fits pretty tightly through the holes, so I doubt there will be much movement at all.
   / L6060 ROPS spare bolts (the ones you remove to fold them)? #14
I raise and lower the ROPS on an M7040SU everytime it goes into my garage. No issue with pulling the pin, and threading them in and out everytime.
It's not that hard?
Status
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
