Land Pride 8' 3 pt. rotary cutter
   / Land Pride 8' 3 pt. rotary cutter #1
nckennedy
Camillus, NY, USA
JD 5425
Just getting ready to replace the cutting blades on the RIGHT side of the rotary cutter and realized that the two cutter spindles move in opposite direction to each other, thus balancing the machine. So when replacing the blades on the right side, are the two bolts a standard left hand thread, or is right hand??
   / Land Pride 8' 3 pt. rotary cutter #2
You can look at a parts list to see if the blade bolts are all the same part number or some are different. I would expect the blade bolts to all be right handed as there's not really any loosening force on them that depends on the direction of rotation. The nuts are tightened down on to a shoulder on the bolt and the blade pivots on the shoulder.
Sounds responsible. Thank you very much.
Craig
   / Land Pride 8' 3 pt. rotary cutter #4
Craig
They are right hand thread both sides. Blades are one side clockwise and the other counter clockwise. Different part numbers.
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
Husqvarna YTH18542 42in Riding Mower (A51694)
Husqvarna YTH18542...
