Landscape Rake Recommendation for BX
   / Landscape Rake Recommendation for BX #1
VH5150
Red Sox Nation
'06 Kubota BX2350
Hi all... I did a search but am coming up empty.
I'm still a newb regarding tractors--this is my first tractor and this will be my first landscape rake.
I'm looking for recommendations for my BX2350. I'd like to try and get as large a rake as possible, but I do not know what my BX can handle. I'm sure a 48" will work fine, a 60" could work, but I'm not sure if a 72" is too big.
I intend to use this rake (1) for spreading loam to plant grass, (2) to rake debris from land I recently had cleared of trees/stumps, and (3) to possibly maintain a 200' long gravel driveway for a home we may purchase this year.
I'd also like a rake with a wheel kit so I can control the depth. Is a wheel kit generally recommended, or is it a waste of money? Again, I've never used a landscape rake before...
Would a cheaper rake (sub $500) from Northern Tool be ok, or should I just suck it up and buy a Land Pride or Woods rake? I sent away for quotes today (Sunday) so I hope to hear back this week on pricing. My gut tells me they're going to be around $1000 though.
Thank you in advance for any replies!
   / Landscape Rake Recommendation for BX #2
I have run landscape on smaller Yanmar tractors
   / Landscape Rake Recommendation for BX #3
Sorry hit send before I was completed. Anyway I have run landscape takes on smaller Yanmar tractors. The smallest I ever ran was a 5 foot no wheel kit. I don't think putting a 6 foot on would've been a problem. They don't take much power to pull. Your biggest problem will be tails swing if you're getting up close to things. I have never used the wheel kit before. I always purchased the TSC brands and never had any problems.
   / Landscape Rake Recommendation for BX #4
I have a Priefert 5 ft rake with wheels. Works fine on the BX. The wheels allow you to adiust them and the toplink to set a chosen gap below the times for delicate raking or spreading.
A 4ft wouldn't cover wheel tracks when angled. A 6ft wouldn't fit my many narrow spaces, even angled.
Bruce
   / Landscape Rake Recommendation for BX #5
I have the Woods compact rake with wheels. It worked perfectly on my BX. It is 5' wide. I now have a B 2620-I could handle a 6' full size rake but mine still does all I want it to. I paid $650 for mine 8 years ago.
Will
   / Landscape Rake Recommendation for BX #6
Right after I bought my 2001 BX-2200 a friend offered to bring his 6' rake over so I could try it. I don't remember the name brand on the rake but it was for full size tractors. The spread of the lifting arms was not sufficient to allow easy attachment of the rake. I got the rake on and found the rake bound up and not working right. :thumbdown: Just measure the distance between lifting arm ends to be sure all will work smoothly. I then bought a KK 5' rake which worked well. Now I have a Land pride 6 ' rake on my Kubota L3800. Probably will never use the 5' rake again. :D
   / Landscape Rake Recommendation for BX #7
I have the 60" king kutter for my bx2360. No complaints.
I think a 60" it shall be... I don't think the TSC or King Kutter rakes offer a wheel kit though. I'll have to Google that further. Thanks!
   / Landscape Rake Recommendation for BX #9
This is just my opinion...based on my experience using a Woods 60" LR...
If you use the tractor for grading works (as in the 200' drive etc.)...I would put the cost of a wheel kit towards a Tilt & Trim package...
Woods wanted more than I paid for the rake (like new at auction) for a wheel kit...using the rake with T&T I found no need for wheels...(side link tilt cyc. is the ticket)
The rake is the best attachment I have for general gravel drive maintenance and recovering gravel that has migrated to the wayside...set the rake at an angle for smoothing wash-boarded areas...
Good Luck...
   / Landscape Rake Recommendation for BX #10
Van Halen,
I just bought a TSC 6' Landscape rake. I used it to rake aprox 4 acres and It worked great. $499 price tag plus a discount made it even better. Well built! I know there are a lot of great ones out there. This TSC brand did exactly what I expected it to do. Good luck.
2015 Ford Focus Sedan (A46684)
2015 Ford Focus...
Case 7-Tooth Soil Controller (A47809)
Case 7-Tooth Soil...
PT 1000 Gal Supply Tank (A47307)
PT 1000 Gal Supply...
2013 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A47001)
2013 PETERBILT 367...
2019 INTERNATIONAL LT625 SLEEPER (A45046)
2019 INTERNATIONAL...
24ft Corral Panel (A47809)
24ft Corral Panel...
