Larger trucks with Gooseneck hitches
   / Larger trucks with Gooseneck hitches #11
If the trailer is that small just let it knife and push it to where you want to go;)
   / Larger trucks with Gooseneck hitches #12
JESSE1 said:
This is the truck I'm working on. A '59 White with a 220 Cummins and 10speed RoadRanger trans. Dad drove this truck when new. Originally had a fifth wheel and pulled semi-trailers. It was made into a wrecker when it was traded in for a new truck in '67. I bought it last year and am in the process of restoring it. Runs good, next step is a coat of red paint.
The trailer is a 28' Fleetneck. I just finished competely sandblasting it and painting it inside and out. Also installed a new floor.
Sweet. Thanks for sharing. That is a nice looking machine. I would like to see a few more pics of the truck, inside and under.... Man that is a pretty truck.
   / Larger trucks with Gooseneck hitches #14
john_bud said:
Handles it is one thing, being able to back it up like a goose? I don't think so.
jb
LIKE a gooseneck, no, but for many people who've only backed bumper-pull trailers in the past, backing a gooseneck can be a religious experience.
I saw a neighbor hauling in a load of baled hay yesterday. He had a gooseneck trailer hooked behind his pick-up, with a farm wagon hitched behind that. I'd have given a buck to see him try to back THAT into the barn....;)
   / Larger trucks with Gooseneck hitches #15
AlanB said:
But as the wife pointed out, how would we use the gooseneck trailer?
Hidden Hitch is one example.
We have a gooseneck hitch in our short bed K1500 to haul our horses around. I wish I would have gotten a Hidden Hitch, but they weren't available when I needed a hitch installed. I can take out the hitch part from the bed, but it's an H shaped contraption with the ball in the middle that's secured to 2 rails with 4 pins. Not as easy as the Hidden Hitch.
Somwhere, I am not communicating well what I am saying.
Let me try again please.
Link
Used Vehicle Sales - Find a Vehicle
search for vehicle # 547481
Like a 24' bed which puts the tail of the truck, well behind where a "standard" (read "my currently owned pulled by my F250") gooseneck would reach.
So, the goose would have to be very, very long, or I would have to chop off part of the bed, or I would have to mount the hitch behind the axle, or Maybe a variation of the above mentioned, mount a goosneck hitch back where a reciever would go.
I am familiar with the larger truck's pulling the campers etc. but then I would always have to pull a trailer, and they are "relatively" new, and not common on the well used market I am shopping. These large flats (or a box I would make into a flat) are fairly common and relatively inexpensive. I could see running 100 miles and picking up a load of plants etc, just using the truck. I would also like to use that heavier driveline to pull the bumper pull dump trailer (bet it would be a bear to back a 10' bumper pull behind that truck :D at least for me) and more likely the tractor trailer, which currently is a 20' gooseneck.
Think I may try going with a small single axle dump (assuming I can farm tag and insure it) and a "new" tag along (probably pintle) trailer.
So, short question, has anyone seen a truck like pictured above, with the long flat bed, towing a goose?
   / Larger trucks with Gooseneck hitches #17
Ah, now I understand.....Nope, never seen it.
   / Larger trucks with Gooseneck hitches #19
I have seen some homemade beds w/ a 2&5/16 ball mounted basically behind the axle on a stiffened crossmember. They look a little goofy going down the road since the gooseneck is acting like a bumper pull. I haven't seen anything like that on a new truck from the factory, these have all been old F700/800 Fords, C30 Chevies and the like. Also I don't know the actual DOT specs on that kind of rig. Of course, we get away with a lot around here w/ a set of Farm Tags. Depending on what you were hauling, you could probably stay w/in the legal limits on the rear axle weight even w/ the above mentioned setup. But once again, I don't know how much attention you would get from a State Trooper.
   / Larger trucks with Gooseneck hitches #20
AlanB, a truck with a long wheelbase like you are looking at will be a real pain with a GN trailer in tow due to the turning radius of truck and especially with a GN in tow, you will be really limited to where you can go with the trailer.
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
Case skid steer wheels and tires (A56435)
Case skid steer...
2016 CHEVROLET Express PASSENGER (A56858)
2016 CHEVROLET...
gps trailers (A56859)
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
FRONT WHEEL SPACERS (A52708)
FRONT WHEEL...
