late 70s case 450 dozer
   / late 70s case 450 dozer #11
Engine Crankcase with filter change - 7 qts (w/o filter change 6 qts) (SAE 30)
Fuel Capacity - 20 gallons
Equipment Hydraulic Resevoir - 7.5 gals (according to the manual, it does take universal hy/trans fluid)
Transmission-torque convertor resevoir - 32 qts (hy/trans)
Final Drives - 6qts (each)
Hawk
Thank you very much. I just pulled the plug on engine oil and thought i saw a little antifreeze hit the pan first any ideas on how thats getting in besides head gasket?.
   / late 70s case 450 dozer #13
I have a pressure gauge that says torque converter would that be hooked to the charge pump? If so mine does the same as yours with shifting and starting until after about 45 mins of run time then it starts to lose pressure and slip but i can let it idle for a minute or two and pat the accelerator and itll jump back up to normal pressure but it continues to lose when it gets hot. The transmission pressure gauge also loses pressure same as torque converter when it gets hot.
I had a transmission to would quit pulling after 30 to 45 minutes when it got hot. Turned out one of the cooling lines coming from the transmission to the radiator was clogged and not letting the cooled trany fluid return to transmission. Ran perfect after I blew the line out then I ran it 5 or 6 hours straight none stop pulling and pushing.
   / late 70s case 450 dozer #14
Hole in cylinder wall from cavitation, sleeve seal leaking, cracked block, best thing I have found is pull oil pan and pressurize the coolant.
Ron
   / late 70s case 450 dozer #15
I have a 70s case 450B, my charge pump went out, replaced it with a aftermarket one found the pump was pushing trans fluid into motor, i have replced the pump 3 different times still same problem. it drains my transmission dry withend 30 minutes into the engine.
2803 (A50460)
2803 (A50460)
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2015 FORD F-650 (A50854)
2015 FORD F-650...
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
2020 KUBOTA RTV...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
