Lateral Sway linkage broke
   / Lateral Sway linkage broke #11
When you mount your box blade, raise it just enough to clear the ground. Then adjust your side links to give about an inch to inch and a half of side to side movement. Raise it to the top and check to see if there is still a small amount of play. If you do it this way it should eliminate your problem.
Thanks for the advise. I have a lot to learn. I also think I am going to look into the telescopic adjuster modification.
   / Lateral Sway linkage broke #13
changing the height of the lift arms doesn't change the tension on the stabilizer links, they are mounted on the same plane as the lift arms. I would suspect that the jerking from side to side when they were too loose is what broke the links.
   / Lateral Sway linkage broke #14
Guess I would take them back to the dealer and see if he will make good and trade the new ones in for the telescoping ones off a 2710. I did what many others have done and got rid of the knuckle busters and have gone to the telescoping arms.
There is a recent thread showing how to make the conversion. Once you have done that then changing out anything on the 3ph is a snap.
CATERPILLAR D6T XL CRAWLER DOZER (A52705)
CATERPILLAR D6T XL...
Valvoline 85/140 Gear Oil (A53117)
Valvoline 85/140...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
FAKE (A52472)
FAKE (A52472)
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
