Lawn Sweeper and Dog Bombs
   / Lawn Sweeper and Dog Bombs #1
ktc007
Howell, Michigan
Cub Cadet GT 2550
I was wondering if anyone had some ideas on using attachments to make poopy scooping easy. I have a 1 ス acre and two dogs that like to use the entire yard, and I do not like to think about doing it by hand. I was wondering if a lawn sweeper or landscape rake would do the job. I am in Michigan and now that winter has broken, I am probably not the only one that has this chore to deal with. Thanks in advance
   / Lawn Sweeper and Dog Bombs #2
If you find one, let me know...
Every time I mow my 1 acre yard, I gotta spend 20mins walking up and down with shovel and bucket...
I think there could be a market there for a budding attachment inventor...!
Its the sloppy ones that you gotta watch out for..(-:
   / Lawn Sweeper and Dog Bombs #3
A lawn sweeper should do the trick. I use mine to pick up aerator cores, which look (and weigh) about the same as your target. :)
   / Lawn Sweeper and Dog Bombs #4
If you use a sweeper I am thinking you are going to need some time for them little bombs to dry out or you are going to flinging fresh Ca-ca all over the rest of the machine... Then you go put it in the shop or garage and guess what it is going to smell like in there..
My daughter and I train Service dogs to help handicapped people. So sometimes you can train Fido to use just one part of the yard.. Just call it Pooh corner..:rolleyes:
   / Lawn Sweeper and Dog Bombs #5
My grass and leaf vacuum attachment does a great job on the residoo-doo from my 4 critters. Even those samples fresh out of the oven. A power wash on the mower deck removes all guilt. Do it when the grass is a bit longer so the 'emptying' part of the job isn't so messy.
Ya I was thinking that a sweeper would need to be cleaned after use. But if it did the job it might be worth it. I wish I had the time and know how to build something, I can't be the only person in need of something like this. Thanks for the ideas
   / Lawn Sweeper and Dog Bombs #7
Sounds like a money maker if you come up with something efficient and practical.. That chore is up there with my other favorite...Scrubbing the toilet.:)
   / Lawn Sweeper and Dog Bombs #8
We have show dogs (SO hobby) and I set the mower deck high for the first cut in the spring. That tends to lift and break up the stuff even if a little of the grass gets cut or doesn't. A rear discharge mower on the tractor is a plus for the -er- rear discharge. Above all, always wear brown shoes and avoid rotary mowers.
   / Lawn Sweeper and Dog Bombs #9
Much worse than cleaning the toilet...and no sink nearby
Andy
   / Lawn Sweeper and Dog Bombs #10
You must be mighty good with that power washer.
I know every time I aim one at any kind of a machine, it always manages to shoot some dirty water straight back at me.
I solved the dog issue by getting more acres. At some point it is better to just say: "I am not going to mow that much land."
Even my wife doesn't think that mowing is a good idea.
Sears Walk Behind Tiller (A44501)
Sears Walk Behind...
2012 Freightliner Cascadia 125 Truck, VIN # 1FUJGLDR2CSBU1926 (A44391)
2012 Freightliner...
John Deere 5055E Tractor with 520M Loader, Low Hours, Limited Warranty Until 2027 (A46877)
John Deere 5055E...
21003 (A44572)
21003 (A44572)
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2017 Ford Fusion SE Sedan (A44572)
2017 Ford Fusion...
