Lawn tractor replacement engine
   / Lawn tractor replacement engine #1
chrissteve
groveland, florida
Craftsmen
I have an old Craftsmen lawn tractor. I need to find a reference chart for replacing the engine. Has anyone find one?
   / Lawn tractor replacement engine #2
:welcome:
To TBN Steve. Need a little more info, like year and model number.
   / Lawn tractor replacement engine #3
Craigslist often has used engines for sale. But as has been referenced, you will need to make sure you know the model you need.
   / Lawn tractor replacement engine #4
You need to know what you have to know what you need.
:welcome:
The lawn tractor is a Craftsmen 10 HP vertical shaft mower..1" shaft, 3 5/32 long inside thread 7/16 20 ... Model 143.991002
Tractor model # 536.270111. Sears referred me to a Tecumseh engine. but they went out of business. Trying to find a Briggs and Stratton. Is there a crossover chart? Please help :confused2:
   / Lawn tractor replacement engine #6
Unless you can find a used or take-off engine that's complete, a new Briggs engine in that HP range (10.5hp) will be in the $700+ retail range. For that kind of money, I'd be shopping for a whole new or used lawn tractor.
   / Lawn tractor replacement engine #7
Here's a 10.5 hp, built by Briggs, with a 1" shaft, and correct shaft length. Doesn't say anything about internal shaft thread size, but I'm sure a phone call could find the answer. Don't know if the bolt pattern would match, but the price isn't bad.
Engines
   / Lawn tractor replacement engine #8
   / Lawn tractor replacement engine #9
Same engine is $295.00 at the Engine Warehouse. New take off's from riding mowers, so they are selling them as scratch & dent specials. Still has 2 year Mfg. warranty.
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
403 (A52706)
403 (A52706)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
