Leak in fairly new Baileys Chief 3 spool valve
   / Leak in fairly new Baileys Chief 3 spool valve #41
There are literally adapter to go FROM everything, TO everything
stupid double post
Ok pics of how the Chief valve is current connected:
Old:
New:
View attachment 518072View attachment 518073
You can see that now that all three Input/Output ports are now connected, whereas before only the P and N ports were. I added a 45 degree JIC adapter to the T port to reduce how bending. Once the other JIC 45 comes in (arrives today), I'll install it on the N port. Also note that I installed a 90 degree on the P port to also reduce hose bending (see 2nd new pic). Note that the PB "plug" is now correctly installed on the N port per LD's instructions and diagram
Hydro block connections:
Old:
New:
View attachment 518076View attachment 518077
I had to kludge the new T input into the hydro block due to clearance issues with the FEL support bar. Fortunately, I had two extra 90 degree JIC adapters (one for the hydro block and one for the other end of the original T line coming off the FEL valve). The clearance now with the FEL support bar is about the same between the bar and the hydro filter. And the hydro filter hasn't been hit yet, os it should be good. You'll also noticed, I eliminated the black iron fitting and replaced it with a NPT-JIC connector so I don't have to fool with the NPT fittings anymore (on that hose at least).
Once again, thanks for all the help: I appreciate it!!!
   / Leak in fairly new Baileys Chief 3 spool valve #44
Thats how it should have been done from the start.
Perhaps with a little more thought and planning for hose routing, things could have been mounted a little different so it would be more "clean" looking and use fewer fittings. Perhaps not.
Ultimately you had to go from -10 ORB ports on the valve to -08 JIC on the tractor. And to 1/2" NPT for the remote couplers. There are dozens of was to accomplish this with various fittings, hose ends, and adapters.......as you have found out.
Really one way isnt any more correct than the other.
What matters is its correct now, and hopefully will solve your leaky valve issue.
378485 (A51573)
378485 (A51573)
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2017 John Deere 8345R MFWD Tractor (A53342)
2017 John Deere...
New Wolverine Skid Steer Root Rake Bucket Attachment 31'' (A53002)
New Wolverine Skid...
