Oil & Fuel Leak in tansmission behind clutch inspection plate
   / Leak in tansmission behind clutch inspection plate
Ok thanks.
   / Leak in tansmission behind clutch inspection plate #12
G'day yes just split undo the four retaining bolts on the housing and replace seal. make new gasket or seal with silicone if the old one not too bad and replace copper washers on bolt, i would not touch the sump ( sorry oil pan!!) as i cannot see how that would leak after splitting the tractor as you do not have to disturb that joint:confused:. Relatively straight forward and easy job just do not forget to wedge the front axle before you split to stop from rolling to one side.
PS use a seal from local seal/bearing supply as they are usually alot cheaper than massey and as good if not better quality just try not to destroy too much so they can get a good measurement
Jon
Ok thanks for the info. I think I'm going to get to try this Monday afternoon. I'll post how it goes thanks for all the help.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55314)
2024 BCL...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A57024)
2019 RAM 5500...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
