Oil & Fuel Leak in tansmission behind clutch inspection plate
   / Leak in tansmission behind clutch inspection plate
Ok thanks.
   / Leak in tansmission behind clutch inspection plate #12
G'day yes just split undo the four retaining bolts on the housing and replace seal. make new gasket or seal with silicone if the old one not too bad and replace copper washers on bolt, i would not touch the sump ( sorry oil pan!!) as i cannot see how that would leak after splitting the tractor as you do not have to disturb that joint:confused:. Relatively straight forward and easy job just do not forget to wedge the front axle before you split to stop from rolling to one side.
PS use a seal from local seal/bearing supply as they are usually alot cheaper than massey and as good if not better quality just try not to destroy too much so they can get a good measurement
Jon
Ok thanks for the info. I think I'm going to get to try this Monday afternoon. I'll post how it goes thanks for all the help.
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A55314)
2023 Kubota Z412KW...
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A52707)
2017 GENIE GTH-844...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
FAKE (A52472)
FAKE (A52472)
