jrdepew
I performed a leakdown on my Ford 1920 today as I have a little smoke the whole time the tractor is running. It is either white or blue, very hard to tell exactly. This smoke doesn't go away when ran hard, just keeps on coming and increases with load. My compressor is suffering from a weak lung, so I could only test with 70psi of input pressure.
Cylinder 1 (closest to radiator) - 70 on inlet, 61 on outlet = 13% leakdown.
Cylinder 2 - 70 on inlet, 45 on outlet = 36" leakdown
Cylinder 3 - 70 on inlet, 60 on outlet = 14% leakdown.
Cylinder 4 - 70 on inlet, 45 on outlet = 36" leakdown
On cylinders 2 and 4 I noticed that I had excess air blowing out of the exhaust stack. I have adjusted the valves late last season, but it is smoking the same before and after. I am thinking I may pull the head this winter and check the condition of the valve seats. While I am in there I would obviously do a head gasket. Because I would have it all apart, I would send the injectors somewhere to get checked. I think this would cover all my bases except for weak rings...I don't intend to do a rebuild of the shortblock unless I see some bad scoring in the cylinder wall.
I used to be into racing and turbo buicks, so engines are nothing new to me...but diesels are. Is there anything else I should do while I'm in there? Any votes for another form of testing before I tear it down? Any other comments? Five angle valve job, bowl porting, teardrop the valve guides, back cut the valves? :laughing: just kidding...I am not hunting for every 1/100th of a second here.
Thanks in advance,
Joe
Thanks in advance,
Joe
