Leaks on new GC2310
   / Leaks on new GC2310 #1
DannyLobster
SW Florida
Massey GC 2310 TLB, Gravely 526
So I got to play on my new ride. After a couple of hours I gave her a look over and noticed one hose on the loader appeared to be leaking. It felt tight though. How torqued should these fittings be? Is there a way to better locate the leak?
Of more concern was what I thought was a fair amount of fluid which appeared to be coming from the Hoe's control levers. Is this normal or expected?
/forums/images/graemlins/confused.gif
Thanks Dan
Thanks Dan
   / Leaks on new GC2310 #3
This is not normal. On a new machine you should have no leaks. I had a leak on a metal connector of my Fel line on a new Kubota B2410. This was a slow drip. I had no luck trying to tighten it. I called the dealer who promptly repaired it under warranty with no charge. I would let your dealer take care of the problem.
   / Leaks on new GC2310 #4
   / Leaks on new GC2310 #5
I would say that they didn't get them on tight enough. Did you put a wrench on the hose that you said looked to be tight enough?
   / Leaks on new GC2310 #6
Yes I did put a wrench on it and it felt tight but I have not run it since. I did not torque it.
There is definately more coming from the hoe control. I think I need to call my dealer. Isn't that what warrenties are for?
Dan
Dan
   / Leaks on new GC2310 #9
Your dealer should take care of it for you. If it is real simple, sometimes it is just easier to do yourself. That is if it's only to tighten up a fitting a little. They can be over tightened and broke, so it would be better is the dealer did that. /forums/images/graemlins/blush.gif
   / Leaks on new GC2310 #10
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
Giyi Breaker Hammer (A57149)
Giyi Breaker...
