LED lights for garage
   / LED lights for garage #51
Just installed 8 of these...
LUMAPRO Flat Panel Fixture, LED, 2 x 4, 3500K - G5544962 at Zoro
Use 60 Watts per fixture vs 94 Watts for T8
At over $700 per fixture it will never pay back...
On the positive side...
They are dimmable and produce less distortion and are very thin with almost zero steel.(non magnetic)
Application is over new MRI machine...
   / LED lights for garage #52
...You likely cannot use LEDs to replace the turn signals on your car. Tried it on our 1983 Benz. Turn signals wouldn't work. Actually, they worked as though the bulb was burned out, e.g. came on but very fast. There's a retrofit for this, but it involves putting a resistor in the circuit. That would defeat the reason for replacing the incandescent bulbs. The resistor would just burn off the electricity as heat. ...
Ralph
Right. The older flashers depend on a resistive load and relatively high current to "flash". You can get around this by replacing your flasher with one designed for LEDs. https://www.superbrightleds.com/search/led-products/flasher turn signal/
- Jay
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
FAKE (A52472)
FAKE (A52472)
Wright Sentar (A50120)
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
