Let's discuss deer fencing...
   / Let's discuss deer fencing... #51
Two years ago I installed the heavy plastic 7' fencing about 18" off of the ground around a 1 acre crop as a test. It kept the deer from jumping over the fence but they starting "bucking" under the plastic netting. I then placed a hot wire about 2' off of the ground all the way around. Problem solved. I will give it another year or so to see if they defeat it.
If you are building this anywhere around Yoakum I would think you would find a lot of local fence builders around there. or maybe they are all working on rigs.
Yes, there are quite a few in the Yoakum area. The initial quote I got was an "on-line" quote and I fully realize it "should" be less expensive to go with a local crew. However, the wife and I have discussed the situaton at length and we are 100% committed to doing the trellis ourselves. So we've got to purchase a lot of the equipment we'll need to do a fence anyway - might as well put it to good use and use it on the deer fence too!
   / Let's discuss deer fencing... #53
Hey, I fully agree with that approach. I look forward to your pictures.
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
ELECTRIC TRICYCLE IRET13 (A55745)
ELECTRIC TRICYCLE...
2001 CATERPILLAR CP-563D PADFOOT ROLLER (A52707)
2001 CATERPILLAR...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
401 (A52706)
401 (A52706)
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
