Leveling Dirt
   / Leveling Dirt
DCS,
I'd forgotten the the 3-pt even had a float postion. It never occurred to me to try using it in that position. I'll give it a try.
Thanks.
Terry
   / Leveling Dirt
DCS,
Thanks.
Terry
   / Leveling Dirt #13
Don't all 3phs float? There's no down pressure on mine so it will float up to the moon but only drop as far as my lever setting.
   / Leveling Dirt #14
   / Leveling Dirt #15
Float position on the 3 pt? Can someone elaborate? I understand the concept of the float on the FEL but the 3 pt?
   / Leveling Dirt #16
   / Leveling Dirt #17
As was said, there is no down pressure on a 3ph. the only thing the position lever does is set the lower limit of the lift arm range, be it at the extreme bottom or the extreme top.
   / Leveling Dirt #18
   / Leveling Dirt #19
Good luck with all the comments you have received so far /forums/images/graemlins/smile.gif
The REAL answer is: gauge wheels. Gauge wheels on every [appropriate] attachment you own.
Cheers!
   / Leveling Dirt #20
Cheers!
Kennco 3pt Single Row Bed Shaper (A50120)
Kennco 3pt Single...
Upright SL-200 Scissor Lift (A50121)
Upright SL-200...
Assortment of Light Poles (A50121)
Assortment of...
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
Coats CHD-9551 Tire Charger (A50121)
Coats CHD-9551...
