Licoln 210 MP on 240v shorted out?
   / Licoln 210 MP on 240v shorted out? #1
BufordBoone
Platinum Member
Tuscaloosa, Al
Kubota L5740 & M7060
I decided to try my Lincoln 210MP on 240 V tonight.
I looked the manual over and didn't see anything saying how to switch from 120 to 240, other than use the correct power cord (it comes with two).
I plugged it all up and flipped the power switch.
The machine appeared to come on briefly, I heard a loud pop and thought I saw a flash in the back of the machine. There was also an electrical smell.
I went to the electrical panel in the wall and the breaker was tripped. This breaker is two switches connected together. Each switch is marked 50A.
I unplugged everything, switched the breaker on and used a multi meter to check the outlet. Hooking between the ground and one of the hots gave ~ 122 V. Hooking between the ground and the other hot gave an identical reading. Hooking between the two hots gave ~244 V.
I am leery of trying the connection again without seeking help.
I am also leery of putting the 120 V cord on and going back to the 120 outlet as I don't know if something in the machine is damaged.
I plan to call the welding shop where purchased and/or Lincoln but also thought I'd reach out here.
What is the best (safest) way to have this checked?
Thanks.
   / Licoln 210 MP on 240v shorted out? #2
If you let ANY of the prepackaged smoke
out I strongly advise taking it to your dealer. That smoke is EXPENSIVE.
   / Licoln 210 MP on 240v shorted out? #3
Yep the smoke isn’t good. Take your meter and check ohms on the cord adapter.....if I’m understanding that right.
Lincoln should have a fuse or breaker in or on the machine. Look through the manual to find that.....that’s a long shot solution though. If your panel breaker was tripped and you smelled smoke I’m guessing something inside the machine shorted and Lincoln will be doing some warranty work/replacement. Sorry it happened- bummer.
Hopefully the 240v plug wasn’t a 120v plug wired wrong or a 240v with a hot and ground switched.....that obviously would do it too.
I'm not understanding what you mean there. I checked continuity on both cords. Based on the one prong that has a "leg" on it (machine connection side, not wall receptacle side), the ground prong is the same on both cords.
I'll bet I've just got a bad machine and Lincoln will make it right.
   / Licoln 210 MP on 240v shorted out? #5
I think it’s my bad for not understanding. You wrote it has two cords 120v and 240v and I conflated that into a cord and an adapter.
Anyway it sounds like you have done everything to verify the power to the unit was and is correct and the problem with the machine is internal.
Those machines seem to be popular from the homeowners to schools to commercial welders. Sounds like a fluke- unfortunately for you.
Sorry it happened and I hope it didn’t hang you up.
   / Licoln 210 MP on 240v shorted out? #6
Sounds like your Lincoln had a leaky smoke tank. Lucas used to sell replacement smoke kits for their wiring harnesses but Lincoln always shunned the practice. Let the dealer sort in out under warranty.
I don’t know if you were trying to be funny or confuse the OP but showing a picture of what is clearly for the Miller Welder doesn’t help- read the part number on the bottle!
He's just being a jerk. Don't know why.
No worries, CD. Hard to understand intent on an Internet forum.
Welder is back to the dealer.
   / Licoln 210 MP on 240v shorted out? #9
My 350mp has a diagram on the back panel showing how to reconnect it for different voltages. I fear yours could be a total loss.
The folks at the LWS told me, just yesterday, that the only thing necessary to change from 110 to 220 was to change the cord.
Lincoln is a good company. If that machine is a total loss I'm confident they will replace it.
   / Licoln 210 MP on 240v shorted out? #11
Let us know what your LWS finds out ??
Consulted with a Master Electrician today to ensure my receptacle does not have a problem. He said "I think you got a bad welder".
I'll update this post once I hear back from the LWS.
I have not forgotten about this thread. Tomorrow will mark one week since I dropped my welder off at the LWS. I've heard nothing so far. I think I'll give them a call in the morning.
   / Licoln 210 MP on 240v shorted out? #14
I would! Often the squeaky wheel gets the grease.
   / Licoln 210 MP on 240v shorted out? #15
And if your like me, that one week probably feels more like one month! Luckily for you your electrician gave your input power a A OK. :)
LWS said "A board was shorted out. It is a warranty repair and we are waiting on parts from Lincoln".
At least that is good news.
No idea how long it takes Lincoln to send parts. I think the MP210 is a fairly popular machine so I'd expect Lincoln to have the parts readily available.
   / Licoln 210 MP on 240v shorted out? #17
The good news is they are not trying to deny their responsibility and put the blame on you.
The bad news is you have to wait for parts.
Ensure they plus the welder into 240 volts before it leaves their shop. Preferably with your cord.
   / Licoln 210 MP on 240v shorted out? #18
Sounds like real good news to me.
I left it with both my cords. Funny thing is the guy on the phone told me the Tech told him "it welded fine on 230 but wouldn't weld on 110".
I suspect he has that backwards.
How come a "110" receptacle reads "122"? How come a "220" receptacle reads "244" (cause 122 x 2 = 244...duh).
I did ask the electrician about my service being higher than the 110/220. He said it is not unusual and that there is an acceptable range of voltage that everything should work in as consumers can't control what the electric company provides.
Kind of explains why the welder says one cord is for 120 V and the other is for 230V. I had wondered how one was supposed to make 230 out of 120 x 2.
   / Licoln 210 MP on 240v shorted out? #20
Better to have a little on the high side than low, I metered mine awhile back and got 124 on each side. For years everyone has called a 120v outlet a 110v and a 240v a 220v ?? lol
VOLVO EC350EL EXCAVATOR (A60429)
VOLVO EC350EL...
UNUSED FUTURE MBD85-85" HYD MINI BACKHOE DIGGER (A60432)
UNUSED FUTURE...
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
1998 MACK RD690S DUMP TRUCK (A60430)
1998 MACK RD690S...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
