Lift arms won't raise and lower with lever
   / Lift arms won't raise and lower with lever #1
POC
Southern Indiana
Mahindra 3215 4x4
Just like the title says, move the lever, nothing. If I reach back and move the little...doodad that the lever moves, it will lift but won't stay up. If I crank the valve under the seat down while I have the arms lifted, they will stay.
Any ideas?
No replies? I thought someone would have a clue of some sort.
If you are on Tapatalk and can't see my info, this is a 3215 gear model.
It seems when I turn the flow control knob something feels "funny". I reckon I'll start there.
Jump in with any advice.
   / Lift arms won't raise and lower with lever #3
Kinda hard to figure out what you're talking about with dodads n such. Are you taking about your 3 point hitch?
Yes, the lift arms.
The "doodad" is officially called something else. It isn't the lever that you move, but the lever moves this thing, which moves things inside the housing.
   / Lift arms won't raise and lower with lever #5
Well you got the problem figured out... why is the lever not moving the doodad... roll pin? broke connection? find were the connection is lost and fix it
It is moving it.
I'll make a video later.
   / Lift arms won't raise and lower with lever #7
so what are you grabing to make the arms lift
   / Lift arms won't raise and lower with lever #8
ok good deal
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
(6) GENERATORS (A55745)
(6) GENERATORS...
Portable Restroom (A54865)
Portable Restroom...
