Lift arms won't raise and lower with lever
   / Lift arms won't raise and lower with lever
Looks like a pin missing so the lever is essentially disconnected from the works. Simple mechanics really.
I appreciate what you are saying, but I don't know where a pin would go.
Anyone have a tractor like this that can look and see if something is missing?
   / Lift arms won't raise and lower with lever #12
Well you already mentioned one empty hole so a pin may have broken and fallen out. If there is a shaft end the lever is supposed to rotate, something has to secure the lever to the shaft in order for the lever to turn the shaft.
Pretty sure it has never had a pin in it.
   / Lift arms won't raise and lower with lever #14
Take a flash light and shine it underneath the seat platform. Look for the linkage coming from the lever next to the seat. Something may be loose under there.
Is there something that connects your lever to anything other than the shaft that it rotates on?
   / Lift arms won't raise and lower with lever #16
The video is too light to see on my screen. If there's a lever moving without the shaft in it moving, something is missing. Pin, bolt, set screw, something.
Mine's made different.
   / Lift arms won't raise and lower with lever #18
Sorry, that's a 2615.
   / Lift arms won't raise and lower with lever #20
You need to show us a video of what's moving when you move the upper lever. What pushes that lower lever?
Native American Wooden Head Statue (A55853)
Native American...
43029 (A51691)
43029 (A51691)
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2018 WESTERN STAR 5700 TANDEM AXLE SLEEPER (A56138)
2018 WESTERN STAR...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
