3-Point Hitch Lift raising by itself
   / Lift raising by itself #11
olts.
It might be elsewhere on this forum, but just in case it isn't, the glow plugs on the 1700 are off the shelf NGK Y-401-3s and are available on Amazon and part stores for $11-13 bucks. The thermostat can be replaced with a Stant 13008 and goes for about $4 at Advance. It's an 180 degree tstat but works fine.
Thanks again,
Kypappy
Glad it work out pappy and it was not more than the simple fix. Great find on the glow plug. I make sure to save it for future reference. I have not had a need for Thermostat yet but keep that info as well. You might pick up a box of assorted cutter pins for times like this. They are pretty cheap at HF and pretty cheesy as well. Sometime a thin nail works fine till you get a new cutter pin.
Welcome to TBN and happy 1700 owners for the most part.
JC,:)
If the lever is vibrating up there is a tension nut on the liever shaft that needs to be tightened. On my 1900 there is a cotter pin that has to be removed to tighten the nut up some.
Bill
Thanks for the tip. Got it fixed today. I found some of JCs posts with a page out of a shop manual and followed the instructions. Quite a chore as the nut and cotter pin were rusted badly. A little persuasion with my lug nut pipe finally broke it loose. Also got the lugging problem fixed by adjusting the linkage.
Thanks again,
Kypappy
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
2001 MACK RD688S WATER TRUCK (A58214)
2001 MACK RD688S...
2018 Bobcat S570 Skid Steer (A59213)
2018 Bobcat S570...
2013 EZ-GO RXV Golf Cart (A57453)
2013 EZ-GO RXV...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
