Lifting Capacity of the Front Mount Quick Attach
/ Lifting Capacity of the Front Mount Quick Attach #1
niedejb
Is there a posted max lifting capacity for the front mount lifting setup for the BX etc series?
I am drawing up a lawn roller to attach to it. I have seen plenty for the 3 pt setup in the rear but they don't accommodate down pressure.
Has anyone tackled this before?
Pick of quick attach below:
/ Lifting Capacity of the Front Mount Quick Attach #2
Why would you want to roll the lawn and then drive over it?
/ Lifting Capacity of the Front Mount Quick Attach #3
hmm - magicheater seems to have a point here. niedejb, can you enlighten us about your future plans for the roller you want to design ?
With the current pull behind types (borrowed neighbor's 60' water filled), seems that there is always a spot or two that the roller will not level.
I figured that I would use the float position for most of the rolling and only apply down pressure to the stubborn parts.
I was primarily thinking of a backdragging use so the driving over the freshly rolled earth wouldn't be an issue.
/ Lifting Capacity of the Front Mount Quick Attach #5
I would guess that it can lift about half of whatever your loader specs are. Just guessing though. Certainly it can't be any better than your loader though.
I'm sure it is only capable of what the single cylinder (pictured) will produce in lifting forces.
Looks like I'm gonna have to build it and hope for the best.
/ Lifting Capacity of the Front Mount Quick Attach #7
Question? Did you just "mock up" your QA for the photo? Is this photo the actual set up you use to plow snow?
The quick attach is the black assembly from the vertical cylinder back. Yes it currently has the plow attached to it. This quick attach is used for sweepers, blowers, plows, etc.
/ Lifting Capacity of the Front Mount Quick Attach #10
I understand, as I had one. Just from the photo, I questioned the location of the top cleats. They didn't look right to my eye, thus the question. The contact was not square to the front bumper of the tractor frame either. That's why I asked if you just mocked up the photo, or if that is how you plowed.
Yes this is a pic of removing the quick attach with the plow (or a mock up). The aluminum trapezoidal blocks that accept the "T" bolts aren't even attached to the "T" bolts. They are simply laying on the horizontal portion of the upper assembly.
I will keep doing my homework. I guess I could find the cross sectional area of the cylinders rod and multiply by the max hydraulic pressure to get in the ball park.
/ Lifting Capacity of the Front Mount Quick Attach #12
niedejb,
Interesting concept you have here. I have a small detatcher that I'm now thinking about mounting to the front quick hitch. Keep us posted. Have you figured out how to keep the roller from rotating around its centerpoint as you try to lift it?
/ Lifting Capacity of the Front Mount Quick Attach #13
Good for you. Keep pondering and engineering things for that front QA. I believe it is a underutilized feature, considering the price. I can envision a number of very useful attachments that I wish Kubota would market for it. johnny type bucket, pallet forks, etc. Keep at it!! Best regards
...Have you figured out how to keep the roller from rotating around its centerpoint as you try to lift it?
Not sure why it would matter if the roller wanted to spin in the up position...can you help me invision the problems with that?
The lifting that I was referring to would be attached to the "axle" of the roller.
(2) UNUSED FUTURE 10' SLIP-ON FORK EXTENSIONS (A60432)
(2) UNUSED FUTURE...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
BUSHHOG RMB1865 DITCH BANK MOWER (A60430)
BUSHHOG RMB1865...
Honda utv cart (A56859)
Honda utv cart...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
