Lifting JD Ballast Box By Top Link Pin
   / Lifting JD Ballast Box By Top Link Pin #11
Actually, come to think of it, while load-testing the boom pole, I lifted the box with (4) 42 lb weights in it, in addition to the concrete, so that made 641 lbs lifted by the top pin.
   / Lifting JD Ballast Box By Top Link Pin #12
What I want to know is, if you needed that much front weight...
...WHAT did you have on the back?:laughing:
:D :D A double pallet of firewood and couldn't set the top one off with the forks on the 3 ph. And didn't want to drop the plow off to attach the FEL. Made do with the ballast box hanging on the snow plow. Worked great for the brief time it was needed to move the double pallets.
   / Lifting JD Ballast Box By Top Link Pin #13
Looks like it did what was needed. Nice looking tractor BTW.
   / Lifting JD Ballast Box By Top Link Pin #14
"Nice rig "
beenthere,
Thanks.
I really like your rear pallet fork adaptation. That one it on my "to do" list also.
I didn't think I needed rear forks until I tried to lift my fully-assembled 46 backhoe with the forks on the loader. Could only get it about 6 inches off the ground, but, fortunately, that was enough to move it.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
Charlotte County (A50323)
Charlotte County...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
