Lifting JD Ballast Box By Top Link Pin
   / Lifting JD Ballast Box By Top Link Pin #1
KennK
NE Wisconsin
John Deere 3320
If I have a JD ballast box filled with cement and try lifting it with a chain attached to the the top link pin ... will it support the weight?
   / Lifting JD Ballast Box By Top Link Pin #4
Yes, you can.
   / Lifting JD Ballast Box By Top Link Pin #5
Runner
Any weight in that ballast box ? :)
Could add chain support to the lower lift pins if worried about the top link pin (I wouldn't, but additional support, including a chain wrap around the entire box).
   / Lifting JD Ballast Box By Top Link Pin #6
"Runner
Any weight in that ballast box ?"
In the configuration you see in the previous picture, it weighs 473 lbs. With (8) 42 lb weights, it weighs 809 lbs.
   / Lifting JD Ballast Box By Top Link Pin #7
Runner
Nice rig :)
   / Lifting JD Ballast Box By Top Link Pin #9
Not always....:D
Sometimes.....
   / Lifting JD Ballast Box By Top Link Pin #11
Actually, come to think of it, while load-testing the boom pole, I lifted the box with (4) 42 lb weights in it, in addition to the concrete, so that made 641 lbs lifted by the top pin.
   / Lifting JD Ballast Box By Top Link Pin #12
What I want to know is, if you needed that much front weight...
...WHAT did you have on the back?:laughing:
:D :D A double pallet of firewood and couldn't set the top one off with the forks on the 3 ph. And didn't want to drop the plow off to attach the FEL. Made do with the ballast box hanging on the snow plow. Worked great for the brief time it was needed to move the double pallets.
   / Lifting JD Ballast Box By Top Link Pin #13
Looks like it did what was needed. Nice looking tractor BTW.
   / Lifting JD Ballast Box By Top Link Pin #14
"Nice rig "
beenthere,
Thanks.
I really like your rear pallet fork adaptation. That one it on my "to do" list also.
I didn't think I needed rear forks until I tried to lift my fully-assembled 46 backhoe with the forks on the loader. Could only get it about 6 inches off the ground, but, fortunately, that was enough to move it.
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
Jaw Crusher (A59228)
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2012 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2012 GENIE...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
