Limitations of a B7800 & Woods BH7500
   / Limitations of a B7800 & Woods BH7500 #1
CNY13
Central NY (north of Utica)
Kuota B7800
I am just about to purchase a B7800 with a Woods BH7500 BH and a Woods FEL. ...not sure of the BH bucket size(s) yet. probably 8" & 16".
Within the next couple months I will be building a 14' x 18' addition with full basement (8' wall) and a attached garage 24' x 30' (4' wall).
The depth of excavation for the addition will be approximately 7.5' +/-.
I don't think the trench for the garage will be a problem but will the BH7500 handle the basement excavation?? ...or should I hire this out to a trackhoe or gradall??
The easy solution is to get a larger Tractor/BH. The B7800 (except for the basement) is suited very well for what I have planned. ie., trenches for drainage & electrical, patios, small ponds, retaining walls, etc.
   / Limitations of a B7800 & Woods BH7500 #2
A modest size trackhoe (miniexcavator) can be rented for about $200. They are FAR FAR FAR superior for the type of excavation you are talking about. I rented a Thomas 35T from Saturday at Noon to Monday 8am for about $160, plus delivery/pick up (total cost was just about $200). It dug a 4' to 5' deep by 6' wide by 40+' long hole in just a couple hours. I could have used the B2910 with Great Bend back hoe combo sitting in the yard, but I figured it would have been 2 weekends of work to use that and the bulk of the problem would have been just moving the machine and the spoils around. I think you'd find the same problem.
Thomas Mini Excavator
   / Limitations of a B7800 & Woods BH7500 #3
</font><font color="blue" class="small">( ...not sure of the BH bucket size(s) yet. probably 8" & 16". )</font>
I have a B2910 with 10" & 16" buckets .... the 16" will plug fairly easily in wet clay. I've never used the 10".
I originally asked the dealer for 12" & 24" buckets but the order got screwed up and I wound up with these .... really wish I had the larger ones. FWIW.
   / Limitations of a B7800 & Woods BH7500 #4
Digging a 7 1/2' depth with a BH7500 will require a lot of moving. The BH will dig 7 1/2' two foot flat right straight down from the BH. I just completed a project that required a hole 6' X 10' X 7' deep. It took a lot of planning and extra moving of the tractor to get the depth all over.
Bobs suggestion of renting a excavator may be the best option for your addition.
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
