Limiter chains too long?
   / Limiter chains too long? #11
Daryl, are you using CAT1 tools with bushings? I have CAT1 and CAT2 lift (4ea, sway/no sway) and top link holes and find it difficult to hook up CAT 1 stuff in CAT1 mode . The top link seems too long for CAT1 stuff especially. I've thought about trimming top link tube so I can adjust shorter, but afraid I might ruin threads. Guess I should run 2 seperate top links. Wondering if you have same problem that you've found cure for?
   / Limiter chains too long? #12
MMM:
I don't have any problem whatsoever. The 5030 came with pins and bushes for CAT2 to 1. I bought a bunch of extra bushes just to have in the tool box. My top link has never been a problem at all. I don't have sway chains on the lower arms. Kubota uses a telescoping tube arrangement with a really wide range of adjustment.
I usually leave the bushes on the pins on the CAT 1 implements. As a matter of fact, I spot welded them on. That way, I don't have to fiddle around with them when I hook up. The only time I felt that the top link was too extended was when the Lucknow 78 is on. To level the blower, the TL must be almost at full extension.
The whole 3 point on the 5030 is very adjustable. When I am pulling the spreader or the MoCo or a rake, I remove it entirely. That way, the arms don't get in the way of the tongue swing. 4 lynch pins and it's off the unit.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2013 BMW 328I (A56859)
2013 International Derrick Digger Truck (A55973)
2013 International...
