little deere gettin it done in the snow.
   / little deere gettin it done in the snow. #11
Man I wish I could use a lawn tractor for 32" of snow! nice work.
I'm starting to think that snow must vary by region as it takes heavy equipment to dig out 32" of snow around here.
Most definitely. If we had 32" here country roads would only be cleared with a Dozer using a V-Plow or a very large blower. I run a JD770G road grader. 245HP, 40K lbs, chained on 4 rear tires. It won't continually push 32" of snow here. :)
   / little deere gettin it done in the snow. #12
He probably kept on top of it throughout the storm. we got 30" in the same storm and there were many, many places where I couldn't push strait with the bucket all the way down. If I did a lot of it came right over my 1 yard bucket. Was a lot of fun though!
   / little deere gettin it done in the snow. #13
Did your tractor come factory with a one yard bucket or did you have it special made for snow?
   / little deere gettin it done in the snow. #14
The factory bucket is tiny. I have a Loflin snow bucket.
   / little deere gettin it done in the snow. #15
I have never understand why tractor manufacturers use such a tiny bucket. I'd way rather have a bucket that I might not be able to lift a heaping load of gravel to full height, but would be far more useful for most jobs.
   / little deere gettin it done in the snow. #16
4570
Can get different size buckets and also different duty... light and heavy.
No matter the size of the bucket, IMO they are too small for snow. :D
   / little deere gettin it done in the snow. #17
4570 Can get different size buckets and also different duty... light and heavy. No matter the size of the bucket, IMO they are too small for snow. :D
But factory buckets are usually too small for anything except liquid concrete.
   / little deere gettin it done in the snow. #18
The biggest problem with a bucket that is too big (deep) is that your curl function becomes less useable.
I actually have 3 buckets, one is 16" wide and 40 inches deep (stump bucket), one is 65" wide and 20"
Deep w tooth bar (Factory bucket), and one is 72" wide and 42"'deep (snow bucket). I find uses for all of them, but use the 65" factory bucket the least and the snow bucket the most.
I use the snow bucket for snow, leaves, wood, as a work platform, to move random stuff - basically for anything except stone and dirt. It easily carries 4x the snow compared to the stock bucket and is hard to beat in deep snow.
   / little deere gettin it done in the snow. #19
4570
What's the biggest bucket you've used? I've seen SSQA buckets up to 108" wide, 40+ inches deep and ~40 inches high. It's like a pusher with the option to pick the pile up
2018 John Deere HPX815E (A50123)
2018 John Deere...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2000 Ford F-450 Service Truck (A51692)
2000 Ford F-450...
