Little grass tufts showing in the mowing cut.
   / Little grass tufts showing in the mowing cut.
They're wore, perhaps more than I realize. I'll sharpen see how well that works. Perhaps get a new set, will need them eventually, if not now, so i can see just how worn they are.
Best place to buy new blades?
   / Little grass tufts showing in the mowing cut. #13
If this keeps happening with new blades, try adjusting the deck according to the manual. I was shocked to find that the little 1/4" forward tilt that they ask for on the deck adjustment made the machine cut like brand new. I had forgotten how perfect it cut when new.
Good point. That's controlled by those bushings and washer that I mentioned where wore. I well check that.
   / Little grass tufts showing in the mowing cut. #15
Remove each blade and lay it flat on a table. Then do the same with the others. You should be able to tell by looking at each if any part of the blade is bent or twisted. Also stack each on top of the other and see if any corners are not touching the blade below or above. Finally, if sharpening the blades use the balancing tool to determine if any blade is out of balance.
https://www.homedepot.com/p/Maxpowe...gclsrc=aw.ds&dclid=CJCrjb6A6NwCFWK2swoda6cJCg
Trump 2028 Decorative Sign (A55758)
Trump 2028...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2015 UTILITY VS2RA...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
Metal Pipes (A47477)
2006 FORD F250 SERVICE TRUCK (A56129)
2006 FORD F250...
BELSHE DT-235 (A53843)
