Loader/Bucket quick attach
   / Loader/Bucket quick attach #1
Chris_VA
Southwest Va
Deere X758
Good morning,
I've searched for the answer to this question but may have missed it. My father has a 1920 with 7308 (I think) loader. Does anyone know if there is a quick attach option we can add to the loader frame and bucket? We are building some forks for it and removing the pins on the bucket takes a lot of time. We'd like to build the frame for some type of quick attach.
Thanks for any advice,
Chris
   / Loader/Bucket quick attach #2
If you are looking for ideas for a good quick hitch, and don't mind looking at a green color scheme, try this link for ideas. It was posted to show the hooks. No apology for the color /forums/images/graemlins/grin.gif
quick attach
Thanks for the post.
Actually, I have a Deere and we've considered purchasing the necessary parts to convert his loader/bucket to the Deere type quick attach. But, that will require some work just to get his current setup to quick attach. Then we'd have to deal with the forks. I was hoping NH had some type of option for this that we could just "bolt on", then we could fab the forks to work with that.
If there is no NH option, we may go the Deere route. Then he and I could interchange my forks and my boom blade.
Thanks again,
Chris
   / Loader/Bucket quick attach #4
If I remember correctly one of the regular New Holland dealers on Ebay had a quick attach for the 7308. I was not interested as with the low lift capacity of the loader already, it pushes everything forward and with the weight of the kit, it would really diminish the lift capacity.
Ah, OK. I just searched for this and found it on ebay. I understand what you are saying about pushing everything forward. May not be worth it. We'll have to study it some.
Thanks for pointing it out to me.
Chris
   / Loader/Bucket quick attach #6
ATI has two types that will fit your tractor. You will have to down load their complete catalog to look at both. The Tach-All which is like a Bobcat quick attach is on page #12. The second style is a pin-type quick attach. The pin-type QA in on page #27. All of the models that both fit are on page 32. The catalog is a very small catalog and doesn't take long at all to down load. It has 36 pages. With the Tach-All type, you have to buy the tractor part plus a plate section for each attachment. With the pin-on type, you just need the tractor section. It uses the same pin holes for attachment that you use now. I have had the pin type for several years now and really like it. Any standard pin on bucket or attachment that was designed for you loader will fit it. ATI
   / Loader/Bucket quick attach #7
Chris,
I have a DX33 Case IH with the L130 loader (same as the 7308). I purchased the Uni-Hitch from Kasco Mfg. Here is their web-site Kasco. I bought the quick-attach plate for the loader ($660) and the adapter plate for the bucket ($290). I also purchased their 42" pallet forks ($720) and like them all very much. These prices were given to me as retail, but I had these items added to my deal when I purchased the tractor. You may be able to get better pricing.
The quick-attach plate is a little heavy, and it does extend the bucket forward a little bit. I have the R4 tires (unloaded) and only use my 72" box blade for ballast. If I load my bucket (60" HD) heaping full of 73 stone, the rear tires want to float a little bit. The loader will only pick the bucket up about chest high as well. But I'm not loading trucks with it, just spreading it on my drive, so I'm happy with that.
I really can't tell you what the performance loss is because this is the only way I have used my tractor/loader (with the Uni-Hitch attached). Overall, like everyone else here, I love my machine very much.
Of course, in a perfect world we would just trade for a new tractor and loader with the factory quick-attach bucket system. But I'm not sure my better-half would approve that transaction /forums/images/graemlins/grin.gif.
Hope that helps,
CBox
   / Loader/Bucket quick attach #8
I forgot to mention that the price for the entire setup for the pin-on type is about what one adapter plate (or less) would cost for the skid steer type.
   / Loader/Bucket quick attach #9
I use an ATI setup on my 2120 loader. Have been using it for years and it works great.
Andy
Hey guys,
Thanks for taking the time to point these options out to me. Dad and I will research the options closely this week. The ATI & uni-hitch setups look promising.
Thanks again!
Chris
   / Loader/Bucket quick attach #11
Chris, I have a Unihitch on my 16LA pin-on bucket. It ads a lot of length to the bucket and seriously effects breakout force. The part that attaches to your loader arms may be okay, but at $600+ it is very expensive. If I had it to do over again, instead of spending $250 on the bucket adapter portion of the Unihitch, and then having to buy four pins to attach it to my bucket, I'd just buy the weld-on plate and pay to have the bucket modified. My NH dealer told me he could get that done for $300 including the plate and I spent close to the same for the Unihitch. On the 7308, I think you'll need all the leverage you can get. 6" or 8" really does make a difference.
Jim,
Thanks for the note. I understand what you are saying about leverage it adds and the negative impact on the breakout force. I agree that is a cause for concern.
Does anyone have pricing on the ATI pin type setup or a link/contact info from a dealer?
Thanks again for all of the help. You all have helped me more than you realize.
Chris
   / Loader/Bucket quick attach #13
I took a look at the Uni-Hitch for the first time to see how it varied from the ATI Tach-All and I see quite a difference in length. I'm not sure of the UniHitch but the ATI adds a max of 2 3/4" I also wanted to say that the 2120 and the 1920 use the same loader. I have not noticed any difference in my 2120's performance since adding the ATI
Uni-Hitch
ATI Tach-All
Andy
   / Loader/Bucket quick attach #15
<font color="blue">Does anyone have pricing on the ATI pin type setup or a link/contact info from a dealer? </font>
The last that I heard was about $250-300. That has been a while, but I am sure that it would still be the least expensive system.
17501-FL (A56857)
17501-FL (A56857)
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
