loader creeps up when 3pt is lifting
   / loader creeps up when 3pt is lifting
Thanks for the replies.
I believe the problem is solved, acting on 'Farmerford's' suggestions I re-examined the return to center spring.
As I think I mentioned the spool in question also had a float detent which was shot. After looking at it more closely I realized the threaded part that holds the spring/detent to the spool had somehow backed out and was not compressing the spring entirely. I did not get a chance to test it under a working condition but it appears to have solved the problem.
Once again, thanks to those that replied and offered suggestions.
   / loader creeps up when 3pt is lifting #12
Seems like I mentioned the lever not centering in post #2.
JJ you did, and I thank you for it, had I realized the implication I might very well have looked at the spring more closely sooner.
Thanks again, it was a post by you in another thread that inspired me to inspect the spool in the first place.
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
John Deere 4820 Forklift (A57453)
John Deere 4820...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
8' ALL HYD SCRAPE BLADE, 3PT (A52708)
8' ALL HYD SCRAPE...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
