Loader refurbishing worse than when I starte
   / Loader refurbishing worse than when I starte
No it shouldn't stay in regen.
And far right, past the little bump is the regen. First position is normal dump
Used the machine yesterday and it's working fine. Cycle times aren't steller, but it seems, after working it a little bit, they've gotten better. Acceptable even. The joystick control is a big improvement over the old 2-lever style and the positioning is better/more comfortable. I think I need to re-check the pressure. I don't want it to be too high. I did lower it when having trouble and then increased it again when I went back to the original pump. However, the fittings on the pressure gauge mounting snot I made were leaking so I removed it. I'm afraid it's above 2500psi which I don't really want. I'll get the replacement fittings and reconnect it so I can re-adjust down to 2000psi. This isn't a big tractor and it's the only one I've got so I don't want to break anything.
Regen is working. There's a noticeable increase in dump speed when going into regen. I think this pretty much wraps up this thread. If I ever come back to the front pump, I'll start a new thread on that. But I'm satisfied with what I've got and it will keep me busy for a while. Thanks to everyone for their input.
   / Loader refurbishing worse than when I starte #122
Glad its working fine
   / Loader refurbishing worse than when I starte #123
Re: Loader refurbishing worse than when I started
Thanks for the update. :thumbsup:
   / Loader refurbishing worse than when I starte #125
Good Luck and safe tractoring !
Perkins 6 Cylinder Power Unit (A57149)
Perkins 6 Cylinder...
JOHN DEERE 310K (A58216)
JOHN DEERE 310K...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
CATTLE HEAD GATE (A58374)
CATTLE HEAD GATE...
2186 (A58376)
2186 (A58376)
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
