loader will not drop
/ loader will not drop
Thanks Egon.... I don't see anything that would be interfering. So far after QD unplug/replug it's still working properly.
/ loader will not drop #12
My old b7500 did that once. Turned out the 3pt lever was slightly engaged and not fully in the neutral position.
x2......Check the 3PH lever is not in the "Full Up" position....the symptoms are exactly like what you say
/ loader will not drop #14
When the loader does not drop, try putting the lever in float and see if it will drop.
If it drops, that means that the QD is good.
If the 3pt lever was causing backpressure, it could cause the loader to stall, and at that point, recheck the 3pt lever.
A 3000 psi hyd gauge will tell you if there is pressure in the flow path, and is a good indicator that something is not right. Should see very little pressure with all valves in neutral.
When using the loader or any cyl and d you see relief pressure on the gauge,and nothing is moving, that is indicative of a blocked QD.
2023 Global Trailers GT302 60YD T/A End Dump Trailer (A59230)
2023 Global...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
