Security & Theft Locking Gas Cap
   / Locking Gas Cap #1
Nathaniel
massey ferguson 1529
I have searched and found nothing. I need a locking fuel cap on my MF1529. I think I might be having fuel stolen. Has anyone put a locking cap on the tractor and where did you get it? Thanks in advance!
   / Locking Gas Cap #2
In the foggy, distant past - one of my vehicles had a locking gas cap. It kept getting water past the sliding key hole cover and freezing. Required a "hot hand" on the cap to release the frozen sliding cover and then a "hot key" to un-freeze, un-lock the cap.
Obviously - I never had stolen fuel. Finally, had enough and replaced it.
BTW - you might want to try Messicks or visit your local MF dealer.
   / Locking Gas Cap #3
You probably could, but most tractors have fuel lines that are easy to get to, so chances are good if someone wants to fuel, they can just cut the fuel line or slide it off and then slide it back on.
Aaron Z
   / Locking Gas Cap #4
You need to set up a critter camera and catch the animal sneaking around your equipment. If they are willing to steel fuel, they will do other things too.
   / Locking Gas Cap
Got one up already waiting to see what takes the bait! I was telling my neighbor about it yesterday evening and it turns out his son’s (who’s off to college) car can’t keep gas in it and he couldn’t find a leak. Now he has a camera up too.
   / Locking Gas Cap #6
"a picture is worth a thousand words"
   / Locking Gas Cap #8
I have a locking cap on my aux tank, but do not lock it. I'd rather them steal the fuel by removing the cap. Any other way will be more expensive to repair than the cost of fuel stolen. But, i also don't have a problem with fuel being stolen, if i did, i may think differently.
   / Locking Gas Cap #9
Have a friend who found simple solution. He placed a 5 gallon can easy to see and it intercepted the person before getting to his fuel tank and filled it with aviation fuel. Said the octane level was high enough it would burn up most consumer engines. Now if diesel fuel and you use off road and they are using in an on road vehicle if you could get the law to test the fuel they could be facing right high fine.
   / Locking Gas Cap #10
He’s wrong about the octane part. I’ve considered leaving gas cans out with mostly water or mixed with sugar.
More info coming soon! (A56858)
More info coming...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
