Locust trees sprayed with 2,4d question
   / Locust trees sprayed with 2,4d question #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I posted earlier about having locust trees sprouting up on a bank we had cleared last year.. I ended up spraying the trees with 2,4d which worked very well.. After a few hours the leaves would start to turn and within a week the trees are brown..
After 2 weeks now all the trees (some are 4' or so tall, but the stalk is about the size of a nickel) are completely brown and the leaves are falling off.. but I have a few questions:
Do you think the roots were killed as well?
Can I safely cut/mow these now or should I wait a while longer?
I am hoping that the roots are killed so they dont regrow next year..
thanks
Brian
   / Locust trees sprayed with 2,4d question #2
I do not believe 2,4d will kill them. If it did I can not see the need for the much more toxic chemicals typically used.
I suggest cutting them and applying roundup to the stumps.
You can find some info here Robinia pseudoacacia - Bugwoodwiki
   / Locust trees sprayed with 2,4d question #4
Check out the link below as it details in depth herbicide use. Some of the chemicals are not over-the-counter products, but can be located.
Look at specifically pages 170-174 of the 174 pages.
http://ipm.ncsu.edu/agchem/8-toc.pdf
   / Locust trees sprayed with 2,4d question #5
I have spent the last 20 plus years as a rangeland and brush control person full time so perhaps I can help you out with your question.
The locusts could be honey locust or black locust. The Honey Locusts have the gigantic thorns when more mature, Black have small one tip thorns only.
2,4-D will not kill the plants. At best you will see brown out and have the impression of success. But next spring they will be back, and if blacks, they will come back with a vengeance since they reproduce from seed as well as from root buds.
There are some excellent homeowner materials that will kill locusts. But there are a couple tricks to employ if you want to be successful.
First is timing. In your neck of the woods, locusts will be most easily killed with a foliar application in mid July on through the end of August. Spraying earlier will provide mixed results to no results.
Look for products containing triclopyr. That is the active ingredient in Crossbow, Remedy, Garlon. For homeowners its easy to use, will not hurt grass and will kill locusts.
If you choose to cut the trees, treat the cut stump with Tordon RTU. Roundup as a cut stump treatment is very unpredictable and on locust is really not worth your time or effort.
there are other methods that I use in my commercial spray business but this is probably the best option for your situation.
Good luck and stay after them, they are a persistant invader.
   / Locust trees sprayed with 2,4d question #6
Wooddust,
I've used Crossbow and appreciate its effectiveness. I am curious as to why it and other herbicides containing triclopyr seem so expensive. Is there a patent involved?
Steve
   / Locust trees sprayed with 2,4d question #7
Its more than that, no it is no longer patented.
Look at any herbicides concentration. For example, Garlon4 and remedy are 4 pounds per gallon of active ingredient. When I spray Remedy for example on sericea lespedeza, I use 1.5 pints per acre. The cost then is not so bad for area covered.
Crossbow contains 2,4-D and triclopyr. Its specific use is for smaller areas, do it your selfers and farmers who don't need 2.5 gallons of each and the mixing issues. its higher cost but you pay for the convenience.
Ortho products sold in the big box stores are far more diluted and are homeowner use materials. Sometimes I wonder how they work but I also understand the average homeowner has zero understanding of his or her spray rate and they likely soak the dickens out of what they want to kill.
   / Locust trees sprayed with 2,4d question #8
Thanks. I paid $160ish for my last 2.5 gallons of Crossbow. I have been using a 2% solution (2 ounces/gallon). I need to check on Remedy and Garlon prices and their labels to see whether they may be more cost effective for me.
Steve
What i used was 'gordons brush no more it' contained 2,4D 2,4DP-p and Dicamba.. I will need to see whether they are honey or black locust as well - i really have no idea..
My biggest problem is that its pretty hard to coat stump because the are less less than size of a quarter (and most are more like a dime size)..
I do have another bottle of week killer that has Triclopyr as the main ingredient.. I will mix some of that up and spray them again..
thanks for all the advise and links
b
Can i safely mix the Gordons Brush no more (2,4D, 2,4DP-p, and Dicamba) and the Ortho Chickweed Killer (Triclopyr) together in the same 1 gallon sprayer?
I was using 6oz/gal for the Gordons (it could be mixed anywhere from 2 to 8 oz per gal - per instructions) and the Ortho is 1oz/gal of water
brian
25ft Tag Trailer (A56436)
25ft Tag Trailer...
2015 CHEVROLET SILVERADO 1500 (A58214)
2015 CHEVROLET...
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
(2) CRAFTSMAN WORKSTATIONS (A58374)
(2) CRAFTSMAN...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
