Log pusher
/ Log pusher #2
How used? Good question. Why so long out in front of crawler too? For higher lift maybe? Did they push a few logs together from the side / middle of the log then chain them to the pusher and lift onto truck from the side? Or did they lever them from the log's end and load from behind the truck. Other then pushing I don't see what you can do with this, and why not push with a standard blade then?
/ Log pusher
I wonder if they loaded like this, but pushed instead of pulled.
A Big Load: 1890s | Shorpy Historical Photo Archive
http://www.connorcoyne.com/blog/2010/03/hungry-rats-a-story-about-evil-lumberjacks/
http://www.fs.usda.gov/detail/superior/learning/history-culture/?cid=fsm91_049843
Bruce
/ Log pusher #4
It looks like they used it for off-loading. Notice in the background of picture 4 - the International R-liner dumping its load. I'm guessing the wood pusher was used for unloading the trailers and the trucks without hoists.
/ Log pusher #5
Nice pictures. When I was a little gaffer, my father drove truck for a local sawmill. This mill used the same trucks for hauling logs to the mill and for delivering dressed lumber, so a sidearm loader (then state of the art for log loading) was out of the question. The mill had 2 trucks (1952 International L-180 series) that usually travelled together when picking up logs so the 2 drivers could load the logs by parbuckling like in the 2nd. photo. I used to go with my father but was confined to the cab while the loading was being done - it can be dangerous. I remember some pretty tall loads (nothing like in the 1st. and 3rd. pictures though). That was before much truck weight enforcement around here.
/ Log pusher
In the 4th photo, I don't see posts on the far side of the trailer. Maybe the trailer posts fold down, 2/3 of the logs roll off, then the pusher pushes off the rest.
Bruce
/ Log pusher #7
Looking at the photos, my first thought was "before much OSHA enforcement" either! ;-)
It's kind of sobering, however, to see "historical photos" dated from when I was a teenager! Ouch!
Very interesting, thanks for posting.
/ Log pusher #8
I think it's for unloading as well. I've seen some footage of a large modern sawmill that uses an apparatus like that mounted on a large wheel loader to off load huge log trucks. It was the Hayes outfit in BC I believe.
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2001 FREIGHTLINER CST120 (A63569)
2001 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
