Log splitter hydraulic fluid
   / Log splitter hydraulic fluid #21
I like gasoila for fittings.. though if you can't find it harvey's makes some good stuff.
soundguy
   / Log splitter hydraulic fluid #22
Hi Guys....
Gonna ask a stupid question here....is the oil used in the ram and pump for a log splitter pretty much a generic hydraulic oil? hmmmm...I guess one has to define "generic" I have an old bare bones log splitter that runs and splits well, but the fluid is really low and I am not too sure the pump isn't starting to cavitate. The only thing I can tell you about it is the ram is suppose to be 22 tons and the moter is a 5hp Tecumseh. Haven't been able to find a serial or model number anywere on this thing. Any thoughts Gents? :confused: Any help would be greatly appreciate as I have two 32 inch Oak tress to deal with. Thanks
Chris
Yes,
and BTW so is the brand name stuff, it is just re-badged with the tractor manufacturers' logos.
It is probably a 4 inch ram.
Without knowing where you are I can tell you that sels for hydraulic cylinders are available to several feet in diameter from a company in Worcester, Mass.
So if it is leaking because you need to re-build the cylinder I can assure you that parts are available.
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2013 NISSAN NV3500 CARGO VAN (A59905)
2013 NISSAN NV3500...
Deere 35P (A53317)
Deere 35P (A53317)
(15) UNUSED 8'X41' PROTECTION MATS (A60432)
(15) UNUSED 8'X41'...
